How would i mod the 12 and 5 volt rails on FSP400-60PFN. It has a vsense line on the 3.3 and looks pretty easy to do with a guide in the forum , but none on the other 2. Here are some specs below i got from Newegg if they might help.
I want to do these mods to see if i can stablize my voltages a bit, 12 volt is 11.68-11.48 and 5 volt seemspretty stable at 5 sometimes dropping. My 3.3 seems to sit around 3.26-3.28. I took these readings from Hardware Doctor on my Infinity
Model# FSP400-60PFN RET
Specifications:
Type: ATX
Maximum Power: 400W
PFC: Active
Power Good Signal: 100-500ms
Hold-up Time: 17ms min.
Efficiency: Min 65%,Typical 70% (at full load)
Over Voltage Protection: +5V ; +3.3V ; +12V
Overload Protection: Not specified
Input Voltage: 100-240 VAC Full Range
Input Frequency Range: 47Hz-63Hz
Input Current: 5A
Output: +3.3V@28A;+5V@40A;[email protected];+12V@15A;[email protected];+5VSB@2A
Specifications:
Type: ATX
Maximum Power: 400W
PFC: Active
Input Current: 5A
