Trying to setup water cooling for my computer but there's so much to look at and after some research i came up with some parts. My budget is about 500ish and noise isnt a big problem. I mainly use my computer for games,movies and school work. Also for the Rad, i want to put it on top where the 2 200mm or 120 fans are, i think the nzxt has both fittings . Im thinking about cooling my gpu also not sure yet. Is it a bad idea to add it in the loop later? or should i just do it all at once? I cant seem to find reviews on a 560 gtx water block, gonna look more.
My build in my computer:
i7 3.4 sandy bridge
gtx 560 ti
8gb gskill ram
NZXT phantom case
Parts for water cooling:
Swiftech apogee cpu block
Ek DCP 2.2 pump
Bitspower Water Tank Z-Multi 150
Aquacomputer airplex PRO 240(possibly idk im juggling around a few RADS not sure what to pick)
i7 3.4 sandy bridge
gtx 560 ti
8gb gskill ram
NZXT phantom case
Ek DCP 2.2 pump
