- May 27, 2002
Waterblock-
Maze 3 "1/2" brass fittings
$42.00 dangerden.com
Would a extra top on the Maze 3 be more or less effective?
or
Gemini Cool High Flow Spiral
$40.00 dtekcustoms.com
GPU Block- I need a good recommendation on this one.
Pump- Eheim 1060 with "1/2"OD brass adaptors
Is the 1060 alittle over board, or should I go with the 1250?
Eheim 1060- $128 dangerden.com
Eheim 1250 with 1/2 adaptors- $68.00 dangerden.com
Radiator- Black Ice Extreme or a car heatercore
This SITE has many car heatercores. Though I do not know which make and model would be the most effective. I heard the Toyota's were good.
Black Ice Xtreme- $68.00 dangerden.com
Car heatercore- $25.00-$40.00 heatercore4u.com
Radiator fan- 120mm Delta 190CFM. Noise to me is not a problem (I actually kinda like it.)
$25 sidewindercomputers.com
Tubing- Tygon tubing R-3603 "1/2"ID
$2.65 per foot dtekcustoms.com
$2.90 per foot dangerden.com
Reservoir- Need a recommendation? Or should I just place a t-piece before the pump as a bleed and fill tube?
Natural Polypropylene "Y" for "1/2" Tubing
$1.75 dangerden.com
This would be for the extra AMD top on the Maze 3. Though if you guys recommend against the top, then I will not need to purchase this.
Metal Worm-drive ring clamps or worm screw type
$5.00 or less, I could probably purchase these from Home Depo/ Lowes, etc.
Case- Need a good recommendation. All I need is enough space to fit the radiator in the lower front part of the case. I'll use my Black and Decker to drill a 120mm hole. I would like it somewhat roomy.
Water Additives - Redline Water Wetter
12 ounces $7.50 dangerden.com
80 % De-ionised/distilled water / 15 % Car Anti-freeze / 5 % Redline "Water Wetter"
Water Flow: Resevoir --> Pump --> radiator --> CPU Block --> GPU Block--> Resevoir
How does this setup look? Price is not a concern, though I would like the best bang for the buck so to speak. I would like to keep it under $500 (which should be plenty, if not then I'll go for the Vapochill). Though, I want a project to keep me busy for awhile, something hands on. The Vapo would not be that fun(already pre-assembled).
I would definitely like your recommendations on the parts listed? As you can probably tell, I'm trying to purchase the most products through the same seller so shipping costs and orders will be less of a hassel. It would suck to order one part from a seller and pay twice that much just for shipping. The list I have came up with was just a "sample". If there is better out there, then please list them.
Thank you all for your time...
or
$1.75 dangerden.com
