- Jan 7, 2012
- Back back in Cali Cali
So I got my hands on this BEAST of a heatercore (its from a military truck, a 7ton to be exact, im a Marine mechanic) Its completely new straight out of the box. A mechanic before me ordered the wrong part and when it got here and i found out we didnt need it i convinced my cpl to let it disappear so now its in my room.
anyhow im not entirely sure what to do with it. I was thinking i could mount it inside a small freezer with its own pump and about a 1 gal container and let it cool that down overnight (antifreeze in it of course) and have it hook up into a quick disconnect so i can connect it to my computer ONLY for a short amount of time to maybe push the cpu further for a benchmark.
READ THIS PART i know a mini freezer CANNOT cool down a pc 24/7 i am fully aware of this i am suggesting this only for short runs for benchmarking. (there now that i said that people will probably STILL point out that a mini freezer cant handle the load over long times)
other than that i dont have any ideas of what i could do with this ginormous core.
some specs on the core
aluminium fins on copper piping
1/2 inch inlet and outlet
4 core radiator
the inlet splits into 4 different paths which converge on the outlet side
the 4 different paths are 1/4 inch piping
the dimensions of the fin area is roughly 9x9x2.5
i also got this badboy it comes out of the same truck this one is used though so a little dirty but i can fix that, i about 90% sure that it works (the truck it came out of didnt run at the time i replaced this but knowing how the previous mechanic was i pretty sure he troubleshot it wrong like the heater core too) its rated for a 24v system but ive tested them on a single 12v batt they just dont go as fast but they do push a LOT of air
now i dont necessarily NEED to find a use for these but can any of you say that given the same chance you wouldnt have snatched these up yourself?
4 core radiator
