- Mar 7, 2008
Modules are Corsair Vengeance RGB 8GB 3000C15 modules. Thaiphoon Burner reports them as Hynix AFR. I have 8 sticks in an X299 system and I need more speed. I've tried a quick search but not got far. What's reasonable expectations for these chips?
On the practical side, setting 3200 16-18-18... booted ok. 3400 at same timings crashed during Windows boot. I got to desktop relaxed further to 18-20-20... then I had a look t voltages. Reported ram voltage was a bit under 1.35V so I gave that a small bump to compensate. SA was just under 0.8v, which seemed really low compared to mainstream boards. Is X299 different or is that just low? IO was around 1.0v by default.
I just tried bumping SA to 1.1v and IO to 1.05v, as well as the ram voltage to 1.37v to allow for the slight droop. That has allowed me to boot at 3400 16-20-20... I suspect for my application bandwidth is more important than timings, within reason. I'm also running 2DPC although I've not tested if that helps over 1DPC in current use case (it does a LOT for Prime95 like loading). Because I have a stupid big Noctua on the system it isn't trivial to remove ram sticks...
