- Feb 5, 2002
- Thread Starter
- #21
p4s are only good cause some of em OC like mad. I would need to OC the p4 50% or its a waste of my money
Overclocker550 said:p4s are only good cause some of em OC like mad. I would need to OC the p4 50% or its a waste of my money
Silversinksam said:
Even though were m8's I think your last statement was a bit well....crazy
But to each thier own, I am an Intel guy and thats my preference, but that doesn't make me right nor wrong
micamica1217 said:
what is so wrong with wanting a 50% OC????
Silversinksam said:
Absolutely nothing my point is that there is a difference between 'wanting' and saying it must OC 50% or its a waste of money.
Just an example, my 2.26bo will do 3.09, using the 'it must' overclock 50% theory would mean I'd have to hit 3.39
Its very rare to find a 2.26bo that will hit 3.39, sure some will, but most won't (average in the database for a 2.26bo is 2858 Mhz) its not a waste of money as I see it. Does that make me right or wrong? who knows Im just making a point
micamica1217 said:
not to nit pick, but, I thought he said...
this sounds like the 50% OC is what "he" needs....
I too do not have a 50% OC....and I'm very happy.
mica
lutjens said:Looks like I'm late to this discussion, but here's my $0.02...
Both companies speed bin CPUs (clock high speed chips as lower speed chips to satisfy demand for the lower speed chips). While AMD has had some good overclockers, Intel has the edge in this category, as refinements to the CPU's design are incorporated across the product line right away. An inprovement in the P4 would be valid for the Xeon and Celeron as well (for the most part). Also, due to Intel's cooler running chips, overclocking is easier as opposed to the high power consumption Athlons. AMD seems to have to introduce a new stepping for each new step forward in clock speed.
Intel is almost always first to move to a new process and is able to gain experience with the new process and refine it before AMD. Thus, their chips on a certain process will overclock better than AMD's chips on the same process. An example of this is the Thoroughbred A vs the Northwood. No contest as to who is the better overclocker. Thoroughbred B is better (as AMD gains experience with 0.13), but still can't hold a candle to the Northwood OCwise. By the time AMD has figured out what they are doing on the 0.13 process, Intel will have moved to 0.09 and the whole cycle repeats again...
My $0.02...
Overclocker550 said:Ok guys lets do the math. I refer to pricewatch for the lowest prices:
1. (SOCKET 478) Pentium® 4 2.0GHz NORTHWOOD P4 - 400MHz FSB - 512K $147
2. Pentium® 4 Northwood A - 512K Cache - Socket 478 - 1.8GHz (1800MHz) $122
athlons:
1. ONLINE ORDER ONLY -
Athlon XP 1700 Palomino 1.47GHz 3D NOW! (Socket-A) 266FSB Processor - CPU $51.30
2. ONLINE ORDER ONLY -
Athlon XP 2100 Palomino 1.73GHz 3D NOW! (Socket-A) 266FSB Processor - CPU $85.24
Ok lets put overclocking aside.
I can get a 2100+ athlon for $85.24
a 1.8GHz northwood is $122! without overclocking, the Athlon wins heads down! If I OC the 1.8 to 2.4 a 33% OC its maybe 10% faster than the 2100+ athlon, but costs 43% more! I did byt a 550MHz celeron back in the days because the cheapest athlon was like $200 for the 500MHz and the 450MHz p2 was like $200 also. The k6-2 were cheap but sucked at games, so it was logical. but the tables have turned to AMD. I may just get an Athlon in a few months unless Intel lowers their prices. $122 is expensive, even as good OC as it may be, I dont need 2.7GHz and the hassle of trying to OC and using expensive RDRAM and an expensive Intel mobo no wonder why I like amd
Overclocker550 said:1.8GHz at 3GHz is not realistic, very slim odds. I said 2.4GHz since this is a 60% chance. at 2.7GHz thats like 20% chance. sure it could happen but its a gamble and if I lose I pay more for less. I could play it safe on an athlon 2100+ or gamble on a P4 1.8GHz and hope I get lucky. If I get it to 2400MHz I still lose cause its only 10% faster than a 2100+ and I pay hundreds more. If I use ddr on a p4, then I lose another 15% performance! P4s are only fast if lucky overclocking. Maybe ill buy one already overclocked to 2.7GHz that someone isnt happy with for cheap and he can buy another cpu and try again
micamica1217 said:OC550,
I have to also agree with what lutjens said.
infact, I thought that I already spoke about the intel chipsets.
looking at your siggy...I see that you have tryed alot of intel chipsets.
well, let me say that you have no idea what you might be getting into with the 4in1 drivers from via. sometimes they are great, sometimes not.
and sometimes they flat out stink.
I know, i've used them for both intel and amd and I'm glad I'm back with intel chipsets.
again, intel chip mobos are no more money then an amd via or nforce2 mobo.
if money is real tight, then maybe going AMD is better for you.
yet if you are a die hard OCer, then you almost can't loose with intel.
just a word about OCing an AMD....
get plenty of screaming delta fans to put on and in your case...
a good set of ear plugs might help too.
my friend lives in coney island, yet you would think that his computer room is right by JFK airport....yes, his OCed AMD rig is that loud.
mica
PhobMX said:
you are right, but there can be silent and well oced comps like mine... its in my living room and it does a little whoose, still has a gr8 oc... 1.8ghz is hard to get with athlonxp 1600 and i can push it even more, just wait till i get my corsair and unlock the chip..
micamica1217 said:
looking good.
I have to say that maybe in the summer you might have to fight heat....
yet here in the winter my friends and I have to fight room temps around 24C-26C.
we get a lot of heat here in New York, and we all like lower temps then normal.
good luck with getting your cpu higher, you sound like your doing great.
mica
