I am not worthy to Water Cooling....
OMFG.... this might be a good lesson for Water Cooling first timer.
This is my story....
My road to water cooling in the beginning I thought it was great, but actually it is not, I was only being a stupid a$$. All the advise so far I received in this forum were absolutely correct.
In the beginning, I want to cool my cpu, my chipset and also my video card. People advise me not to cool my chipset and my video card but I didn't listen. People advise me that a T might be better than a resevior but I didn't listen.
The first time I am trying fill up water into my system in my case.. I had a spill. It was all over my 8KHA+ mobo and my VisionTek Geforce 3 original. I was filling the resevior too fast and it was full and the water start coming out from the resevior. (my resevior is right above my CPU) I panic and scared to death. I spend the next 30 mins wiping out the water. Miraculously, my first attemp to boot the machine, everything works. It was damn cool. I was cooling my cpu, mobo chipset and video card using a parallel. 3 days later, my Geforce 3 is gone. I don't know it was my failed video card cooling or it was that spill made my GF3 R.I.P.
About a week ago, I was posting question about my water temperature. At first I thought it was my radiator failing but everyone point out it was my waterblock did not have a good contact with the cpu die. This time I learn my previous lesson. They told me the 4 mounting hole kit is better than socket hold down device. So I order the 4 mounting hole kit (they are not here yet.. but will be tomorrow). Mean while I am getting insane temp like 49c at stock speed. Just out no where, I decide to use my CoolerMaster HHC-001 ( and yes.. it is loud... now my computer is like a jet taking off) one more time. Guess what, my idle temp @ stock speed is 28c compare using water block it was at 39c. the ambient temp is the same. Full load using HHC-001 was 34c compare to 49c using water block.
My advise is, listen to others and don't be a smart ***. If you don't, you will be like me.... ...
I will do a push and pull setup for my radiator as well because many people said it works great!.
