- Apr 27, 2013
990FXA-GD65 with AMD 8350
those with these names on, "MSI" & "Military Class"
I overclocked to 4.4 with 4.8v and everything's temps are under 45 and maybe goes for 50 in full load but these two heatsinks cross 75 and cause system crash
currently I've just faced a normal 120mm fan on "MSI" one, a lil angling toward the other one but nothing happens just decreased the heat rising, wont stop it at any level
i used a smaller fan beside the 12cm one to no avail, even using silicon on "MSI" heatsink to stick it to a CPU FAN with a heatsink mounted, nothing, the temp didnt transmit to the CPU FAN's heatsink, i realized for doing that i need pressurizing the junction but this stupid MSI heatsink wont let it, its not flat as its seems from above
the other one is kinda hiding under a big cooler Z600 with two fans mounted
when running occt or p95 and cpu load is 100 this happens but when playing games in full load the temp stuck at 60/65 sometime getting close to 70
really need help
thank you
really need help
thank you
