Thanks for those tips. That's the gadget which I needed...
After some averange requerement game:
http://oi46.tinypic.com/30ldojt.jpg
After something, about 20 or evel less minutes at PRIME95:
http://oi49.tinypic.com/2z9cmc5.jpg
I've downclocked my last OC a little... The FSB from 214Mhz to 210Mhz (from 3210Mhz to 3150Mhz of CPU cores, and the memory clock automatically from 1426Mhz to 1400Mhz).
I didn't want to check my stability etc. I Just wanted to be sure, that the TEMPERATURE#2 is the sensor of the CPU from the motherboard. When i hit the 60*C the BIOS BEEPed again. So i know what is the TEMPERATURE#2.
The TEMPErATURE#3 is this, what I was talking about in earlier post - it's always on the 79, 80 or 81 *... So the TEMPERATURE#1 is the temperature of the My Northbridge? PRIME95 is not making any load on it?
EDIT:
I Left My PC "sleept" on a couple of minutes, and TEMPERATURE#1 after waking up was on 33*C. So i think, that I Found a program and sensor, that I can check My NORTHBRIDGE temperatures
. Thanks...
Tomorow i will do some tests while gaming and check out what temperatures it's gonna get on that kind of load
... I won;t forget, to post a results here
Thanks a lot
tikithorsen!
