- Nov 14, 2009
- Pleven, Bulgaria
Uhm yeah, I'm either cursed or Gigabyte doesn't really care about their AMD customers...
A few things that bother me on this board:
CPU voltage - The default voltage of my CPU is 1,375, but it seems to be running at 1,392v.
POST -Doesn't show any info whatsoever, all it does is say "loading operating system", which is being displayed anyways, even if you don't press TAB using F4 BIOS.
F1 came with a bug, pressing tab will do the same thing, but it will also disable your keyboard input, which can only be fixed by restarting the PC.
NB temp: the NB heatsink feels like my old passively-cooled HD4550, it gets really hot (no idea about the actual temp) so now I have to find a small a*s fan for it.
No heatsink on the MOSFETs - means I'll have to buy small RAM heatsinks and try to figure out how to actually attach them.
Am I creating myself unexisting problems or did Gigabyte really fail on this one?
