- Apr 26, 2004
- The Netherlands
- Thread Starter
- #41
jamesavery22 said:Mounting holes dont bother me much. Not hard to manufacture a new mounting plate for pretty much anything so it can use the stock P4 retention mechanism and the clips that come with the adapter's heatsink. Having just 4 holes is even easier to use.
Anyone else with some OC stories? No ln2 prefered =)
Jimbob7 said:Mounting seems simple when you look at it, but its alot harder than you think . Because of the TDX it makes things alot harder, but evenstill, its no simple task unless you get lucky with the componets you have somehow.
How does it get harder exactly?Jimbob7 said:Mounting seems simple when you look at it, but its alot harder than you think . Because of the TDX it makes things alot harder, but evenstill, its no simple task unless you get lucky with the componets you have somehow.
Gautam - surely you must know someone with a P4CPU, or even a celly?
I know it was on the XS forums the guy had a small cad pic of what it might look like but i do think someone said there would be problems do to the weight of the hsf/block i cant find it right now but when i do ill post a link. But with raising the intel bracket has anyone actually tried it? if not i get my 479 adapter later this week and have a dead is7.... think i need to make a few trips...Jimbob7 said:Don't suppose you have the link to that do you? It sounds very interesting. When i get all the stuff i'll have a good play around with it, but i think all ideas have been thought up including your contribution.
