I have just purchased a 3.0E and i want to overclock it but i have heard they run really hot. i would like to get a watercooling system but that is out of the queston for right now. does anybody have any good ideas for me?
woohoo, a free post ThermalRight SP-97 and a vantec tornado (92mm) is the best air cooling, for a quieter option, get a 92mm fan you like and a rheostat (fan controller). Welcome to the forums, and for future reference, use the search function (thats what its there for)
For serious Prescott OC'ing you need to do Watercooling. However, like SewerBeing said, you can use a SP-94 with a Toranado and still get decent results.
you mean a ThermalRight SP-94...its an Intel chip also, ive heard a very good setup is that heatsink with a 80mm or 92mm Tornado fan (depending on whether you fancy pressure - 80mm - or cfm - 92mm -) on a rheostat or 7volt modded (permanent). if its on a rheostat, you can turn it up for benchies and down for normal use. do this or get a 80mm or 92mm fan of your choice (i prefer panaflo personally).
When I run it at 3.6 to show off, Runs at 49 degrees idle and 75 degrees full load. That's at 1.5125V and my TWINX-3200 running at 5:4. I wouldn't want to run it at that all the time although I had it at this for about 6 weeks no probs.
For everyday use, I run it at 3.08GHz with my RAM at 1:1 and at 1.4125V. The temps are 46 degrees idle and about 61 degrees full load.
I HIGHLY recommend watercooling for prescotts but your next best bet is my Zalman
True. They require quite a loud fan to force the air between those tight fins. You could get a 120mm fan and a shroud sort of thing and that would be nice
