Dear Forums,
I am familliar with the use of overclocking tools, hardware & cooling. However, for my new build i've just done i've followed this specification.
Sabertooth 990FX Am3+ (OverTheTop..)
HAF-X From CoolerMaster (Big!)
4GB Of Elixer Memory (Old Rig DDR3)
60GB OCZ SSD (Booooot!)
AMD Phenom 965 Black Edition Quad (Old Rig, works fine)
AMD Radeon HD 4850 (Old build, intent to upgrade shortly).
I am fixated on the dilemma I find myself in, I currently have an old OCZ Cooler on my CPU, it does the job fine, it idles at around 38 with an overclock from 3.4 to 3.7. However load temps using prime will quickly escalate this to around 60-65. Not the best of temps I would like to have.
I have always wanted to try one of them "all in one" kits for watercooling, the Antec Khuhler stands out, with the RGB lighting the flexy cables & the efficency, but so much goes wrong. As with the H80, There are many problems with both Corsair's and Antecs All in one WC. -- I've heard horrors of leaks, rattling, pump problems, the Antec is the worst, or atleast to what i've heard you have to install some drivers before the pump even works? USB header? What?!
So, i've been talking to some people on youtube & irl, and to be honest, I don't need a mega-cooling solution, getting this CPU to 4.0 or 4.2 and idle temps at around 30 and load to 60 will make me happy.
However, im not sure on my decision, Conventional Air or Water Cooling?
So, members of the OCF, I pose this question.
What cooler would you recommend to me and why.
Regards,
Chris.
Regards,
Chris.
