- Dec 1, 2007
- Near Toronto Canada
(Sorry meant 4Ghz)
Prime 95 'max cpu heat' test after 15 mins only high 60s!!
Issue: 1024K length DID NOT complete on one of the threads. See above.
Overclock settings used were :
Asus RampageIII Formula
Extreme Tweaker
Target CPU Frequency...............: 4.0GHz
Target Dram Frequency.............: 1523Mhz
LN2 Mode
QPI Load Line Calibration
_____________________________________
Extreme tweaker
Sync Mode..................................: Disab.
A1 Overclock Tuner......................: Manual
OC from CPU Level Up...................:Auto
CPU Ratio setting..........................: x21
CPU Turbo Power Limit..................:Enab.
<CPU Configuration Sub Menu>
CPU Ratio setting..........................:x21
C1E Support.................................isab
Hardware Prefetcher.....................:Enab.
Adjacent Cache Line Prefetch.........:Enab.
MPS and ACPI MADT Ordering.........:Modern
Intel(r) Virtualization Tech...............:Enab.
CPU TM Function.............................isab.
Execute Disable Bit..........................:Enab.
Intel(r) HT Technology.....................:Enab.
Active Processor Cores.....................:All
A20M..............................................isab.
Intel(r) Speedstep(TM) Tech.............isab.
Intel(r) C State Tech*.......................isab.
*C State package limit setting............:N/A
*C1 Auto Demotion...........................:N/A
*C3 Auto Demotion...........................:N/A
Extreme Tweaker(Continued)
BCLK Frequency.................................:190
PCIE Frequency..................................:103
Dram Frequency.................................:1523
UCLK Frequency..................................:3237
QPI Link Data Rate...............................:6857
Memory Configuration Protect...............isab.
<Dram Timing Configuration Sub Menu>
1st Information
CAS# Latency (tCL).........................:7
RAS# to CAS# Delay (tRCD).............:7
RAS# PRE Time (tRP)......................:7
RAS# ACT Time (tRAS)....................:19
RAS# TO RAS# Delay.......................:4
Ref Cycle Time.................................:60
Write Recovery Time.........................:8
Read to Pre Time..............................:7
Four Act Win Time.............................:Auto,
Back to Back Cas# Delay.....................:Auto,
2nd Information
Timing Mode......................................:1N
Round trip Latency Channel A...............:Auto,
Round trip Latency Channel B................:Auto,
Round trip Latency Channel C................:Auto.
3rd Information
Write to Read Delay (DD).......................:Auto.
Write to Read Delay (DR).......................:Auto.
Write to Read Delay (SR).......................:Auto.
Read to Write Delay (DD)........................:Auto.
Read to Write Delay (DR)........................:Auto.
Read to Write Delay (SR)........................:Auto.
Read to Read Delay (DD).........................:Auto.
Read to Read Delay (DS).........................:Auto.
Read to Read Delay (SR).........................:Auto.
Write to Write Delay (DD)........................:Auto.
Write to Write Delay (DR).........................:Auto.
Write to Write Delay (SR)..........................:Auto.
Extreme Tweaker (Continued)
CPU Differential amplitude..........................:700
CPU Clock Skew.........................................:normal
IOH Clock Skew..........................................:Normal.
Extreme Engine Digi+
Digi+ Power Mode.......................................:t-balance
PWM Voltage Control...................................:Auto
Load-Line Calibration...................................:0%
CPU Voltage OCP.........................................:Enab.
CPU PWM Frequency....................................:Auto.
Extreme OV.................................................isab.
Extreme OC.................................................:Auto.
CPU Voltage.................................................:1.325v
CPU PLL Voltage............................................:1.802v
QPI/DRAM Core Voltage.................................:1.28125
DRAM BUS Voltage.........................................:1.590
<Dram Reference Voltage Sub Menu>
DRAM DATA Ref. Ch.A.....................................:Auto.
DRAM CTRL Ref. Ch.A......................................:Auto.
DRAM DATA Ref. Ch.B......................................:Auto.
DRAM CTRL Ref. Ch.B.......................................:Auto.
DRAM DATA Ref. Ch.C.......................................:Auto.
DRAMAuto. CTRL Ref. Ch.C................................:Auto.
IOH Voltage......................................................:1.15275v
IOH PCIE Voltage...............................................:1.5105v
ICH Voltage.......................................................:1.113v
ICH PCIE Voltage................................................:1.5105v
CPU Spread Spectrum.........................................isab.
PCIE Spread Spectrum.........................................isab.
I essentially copied this person's settings:
http://www.clunk.org.uk/forums/revi...e-iii-formula-living-review-2.html#post100213
Only difference was I left my PCIE at 100MHZ and also I set the RAM settings to those for MY ram, not this guy's.
Feedback please. Cheers.
i7 950
ASUS Rampage 3 Formula
Mushkin 1600MHZ CL7 DDR3
Radeon 6870
Noctua NHD14
HX 850W corsair
Extreme Tweaker
LN2 Mode
Extreme tweaker
1st Information
2nd Information
3rd Information
i7 950
Radeon 6870
Noctua NHD14
HX 850W corsair
