Hello everyone! I'm new here. This is my first post and I really need some help from you guys. I have an issue with my new motherboard. I have an i5 4670k. On my old msi z87 g45 mobo, overlcocking was simple and I never had an issue. With this one, some weird and annoying things are happening. I'm trying to get my cpu to 4.4ghz (where I had it on my last mobo) and every time I restart my system or wake it up from sleep, it will revert to 3.6ghz at 1.18 volts. When I go into the BIOS, my voltage offset settings are where I left them and so is the multiplier settings. I have it set to +90 on the offset voltage to acheive 1.244 volts at 4.4ghz which I am 100% sure is stable. When I change the multiplier to anything other than 44 and then change it back and reboot, it will work. My overclock sticks. But as soon as I restart or it goes to sleep, it goes back to the 3.6ghz/1.18 volts again. I have absolutely no idea what is going on here. The only settings other than the multiplier and the voltage offset that I have changed are the ram XMP and the boot options. Didnt touch anything else. Does anyone know what the problem is? Thanks for taking the time to read this.
