- Dec 4, 2010
- Thread Starter
- #21
The SSD burnt at the connection not inside.
Put the paper clip into the connector as shown, make sure you're holding it so the ATX hold down clip is toward you . The green one 4th from right is the power on signal so one end in it and the other into one of the adjacent ones marked in yellow. Then turn the power on. If you have a DMM you can check power outputs if you want to go that far but you should know whether it works or not as soon as you flip the switch.
I will be very happy if it's just the PSU and not the mobo. Not looking forward to cleaning, re-seating and re-applying thermal to the CPU on a new mobo. Then of course I will wonder how the hell I wrecked a brand new PSU.
