- Aug 12, 2010
- Ringgold, Ga
[Solved]I think I'm ready to take the plunge.
Currently have the H50, and it's not keeping up with my OC.
So now, I'm going to try my hand at real water cooling.
After spending the last two weeks reading stickies here, and elsewhere, I think I have my first loop planned out. If you spot anything that you would change, please let me know.
My first attempt at WC will be a cpu loop only. Later I might plan to go after a pair of xfired 5870s in a second loop, but the Vapor-X cooling is more than sufficient for now.
I7 860 - currently at 3.5 ghz and wanting to push to 4+
Case: Thermaltake Element G
Using OCCT I hit temps approaching 80 (76-75-75-76) in a room with 23 ambient.
Now with what I plan.
Radiator: Black Ice GTX Gen 2 Xtreme 360 (1/2 in. barbs on everything)
Fans x3: Scythe SFF21G S-Flex (75 cfm)
CPU Block: EK Supreme HF
Pump: Swiftech MCP 355
Pump top: XSPC Top
Reservoir: Swiftech MCRES-Micro High Flow Res.
Tubes: 1/2 in ID tubing from whatever local hardware store has.
PT Nuke
Distilled Water
Loop will be: Res > pump > radiator > cpu > res.
Thoughts? Have I missed anything or picked any poor products? I'm currently looking to hit a 5-10 DT out of the radiator.
For the future gpu loop I'm thinking about almost the exact same as the CPU but going with Koolance water blocks, yes I saw the history, but I also saw these blocks tested good. 1/4in ID tubing.
Now as I understand it, I need to clean each piece before installation. I also need to clean the system about once a year.
Should need no more than 2 drops of PT Nuke.
Make sure all air bubbles are out of loop before firing it up the first time by rotating the case and tapping the water block with a screwdriver handle, or something similar.
Keep the reservoir above the pump to make sure it doesn't run dry.
I should probably stop rambling now.
Thanks in advance.
Pump top: XSPC Top
PT Nuke
Distilled Water
Thanks in advance.
