- Oct 29, 2011
- Louisiana
new to the whole OC scene but i think im well prepared as far as heat sinks and fans. i have an XFX 6990 vid card that is bottle necked cus of my CPU, or so iv been told.
i want to OC the CPU enough to fix that, but without phase changing, liquid if all possible, i do have the cooler master v8 heat sink, aluminum i know -.- need copper, for my CPU.
now i need to upgrade the cpu heat sink to copper but i cant find a really good one that doesn't knock off my ZM-RC 1000 ram cooler, had the corsair dominator triple fan but it sucked allot of *** and made way too much noise. any suggestions on a kick *** copper heat sink for the CPU
i also have the EVGA power boost that goes in the pci slot to prevent power loss to the GPU from the pci slots, not sure about any benefactors from it but it had good reviews, and it was like 4$.
my PSU is a Kingwin Mach 1 1000w, and yes it powers the whole system, im aware that i might need a second PSU for my 6990 so i can OC the CPU, preferred not to but whatever is the safest.
by the way money is no option you get out of your system what u put in. is what i believe.
now here is my systems current specs summerized:
OS
MS Windows 7 64-bit SP1
CPU
Intel Core i7 Extreme 965 @ 3.20GHz
Bloomfield 45nm Technology
RAM
12.0 GB Triple-Channel DDR3 @ 674MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co., Ltd. EX58-EXTREME (Socket 1366)
Graphics
AMD Radeon HD 6990 (XFX Pine Group)
CrossFire Disabled no second card...yet: comp:
CPU specific specs: Intel Core i7 Extreme 965
Cores 4
Threads 8
Name Intel Core i7 Extreme 965
Code Name Bloomfield
Package Socket 1366 LGA
Technology 45nm
Specification Intel(R) Core(TM) i7 CPU 965 @ 3.20GHz
Family 6
Extended Family 6
Model A
Extended Model 1A
Stepping 4
Revision C0/C1
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64
Virtualization Supported, Enabled
Hyperthreading Supported, Enabled
Fan Speed 1268 RPM
Bus Speed 134.9 MHz
Rated Bus Speed 3237.0 MHz
Stock Core Speed 3200 MHz
Stock Bus Speed 133 MHz
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 32 KBytes
L2 Unified Cache Size 4 x 256 KBytes
L3 Unified Cache Size 8192 KBytes
RAM specific specs:Corsair TR3X6G1333C9 XMS3 PC3-10666 1333MHz 240-Pin DDR3
Memory slots
Total memory slots 6
Used memory slots 6
Memory
Type DDR3
Size 12288 MBytes
Channels # Triple
DRAM Frequency 674.4 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 51 %
Total Physical 12 GB
Available Physical 5.79 GB
Total Virtual 24 GB
Available Virtual 17 GB
SPD
Number Of SPD Modules 6
now i am aware that upgrading my RAM to the fast 24gig would be nice but 12 does what i need it to do for now, cooling to me is more important lol,
unless it would help with the bottleneck issue sigh*
OS
CPU
RAM
Motherboard
Graphics
Cores 4
Threads 8
Technology 45nm
Family 6
Extended Family 6
Model A
Extended Model 1A
Stepping 4
Revision C0/C1
Fan Speed 1268 RPM
Bus Speed 134.9 MHz
Caches
Memory slots
Used memory slots 6
Memory
Type DDR3
Size 12288 MBytes
Channels # Triple
Physical Memory
Memory Usage 51 %
Total Virtual 24 GB
SPD
