I built my computer about four months ago and it has been running superbly. Recently I figured I might as well get my money's worth out of my Sandy Bridge so I researched overclocking, since this was the first time I had attempted it.
I initially followed this guide: http://www.bit-tech.net/hardware/cpus/2011/01/07/how-to-overclock-the-intel-core-i5-2500k/1
It worked for a day but then I started to get some worrying BSOD's and it automatically reset the BIOS settings.
So I looked some more and found this thread: http://forums.legitreviews.com/about33850.html
This setup seemed more fitting for my purposes, so I followed his method exactly, except I set the core multipliers at 43. However, when I started up the computer, all cores were running at 4.3GHz at idle with temperatures in the low to mid 30s. Without overclock, they sit at the mid to high 20s at idle.
Why is the turbo running at idle? I thought the multipliers were only meant to increase under load.
