- Jul 4, 2011
- North Carolina
Just finished building my new rig (need to post it in my sig, I know!), and started into OC'ing my new i5-2500k. Here's my relevant specs:
Asus P8P67 Pro (BIOS 1850)
Intel Core i5-2500k
Corsair H60 with 2 120mm fans in push/pull
Kingston HyperX 1600mhz ram (4gbx2)
So I started out with an easy OC to 4.4Ghz (can't remember what Vcore I used exactly, but I think it was around 1.3v) and then wanted to go higher, so I bumped it up to 4.8Ghz, and added some more Vcore (again, not sure exactly how much I tried, I think it was 1.38v to start with) but I kept getting BSOD's with the 0124 code at very random times (never in game, but sometimes after quitting a game, and sometimes just idling on my desktop), and it would freeze fairly frequently at the Windows boot logo, and I would have to hard reset it. I also couldn't get it to pass Prime for more than 1hr before I got a BSOD.
So I decided to see if I could get it stable, so I read a bunch of stuff about OC'ing these chips, and on this board. I started increasing Vcore first, and got all the way to 1.425v with LLC on extreme, "CPU Current Capability" on 120%, VRM on 350Khz, and Phase control and Duty control on Extreme. Still got the BSOD and freezes on the boot logo.
Then I read about increasing QPI/VTT/VCCIO, and also read that your QPI/VTT/VCCIO should never be more than 0.5v less than your RAM voltage (my RAM runs at 1.65v, and my VTT was at 1.05v, so I was freakin out!). I immediately changed that to 1.15v, which seems to have helped a lot, as I can now pass Prime95 for 4hrs (haven't tried longer) and haven't had a BSOD yet, or a boot logo freeze (it's only been a day though, so I have my fingers crossed.
So my main questions are, is 1.425v (1.448v at full load in Prime95) too much for a constant OC (my computer only runs about 12-14hrs a day, if that changes anything)?? Plus it seems higher than what a lot of people are having to use, may just be an ok chip though, and they have awesome ones. My CPU temps currently max at 81c, with the coolest core being 74c.
And also, does your QPI/VTT/IMC/VCCIO voltage really need to be >0.5v away from your RAM voltage, or does that matter?
And lastly, my CPU doesn't seem to drop frequency or Vcore any more. Not sure why, as I've triple checked that EIST and all the C modes are still enabled. Any idea as to why that might be? And should I disable EIST or any of those modes? I would like to save some power if I could, but not at the expense of my OC
Thanks for the help, as this is my first real PC, I really don't want to kill it!
Edit: forgot to post that I also raised the PLL voltage to 1.8125v, as I had read was good to do.
Intel Core i5-2500k
