Hi guys
I followed this guide (http://www.overclockers.com/forums/...Beginners-How-to-set-your-25-6-700K-to-4-5Ghz)
And have a stable OC at 4.5 GHz at 1.33 V. System is still very cool, around 50 degrees Celsius after 6 hours of Prime95 and an Intel Burn test. LLC was set to 75% to make this stable
Making an assumption that I have plenty of head room temperature and voltage wise to chase down a 5.0GHz OC. But in the guide post it mentioned starting a new thread for obtaining speeds over 4.5 GHz
Is there any thing additional I need to know, or do I keep increasing core clock and voltage until I find stability. With out going over 1.4V ?
Additional side note, I can not select XMP on my MB and my RAM speed was set manually off the manufacturers spec sheet. (I do not know if this makes a difference)
