I swear in 1366 every single Mobo is slightly different and in my experience it almost feels like these CPU OC's are Mobo Dependent when it comes to how far you can OC on ambient(read Air).
I've OC'ed 4 Different 920-930 I7's over the past few years(on dif mobo's) and most will do 3.7-3.8 - Those same CPU's may do 4.0-4.2 in a different mobo though.
But one thing is for sure that you will hit a wall with the chip where throwing more volts doesn't really help with much but adding more heat to the load temps and at that point its almost always better than to just stop because that extra 100-200mhz will just end up unstable or on the ragged edge of stable where a temp change or degradation will end up hurting you in the end..
When i RMA'd my mobo (Asus - P6T Deluxe) for this work unit that is running a 930, the prior mobo ran it @ 3.8Ghz before I ran into heat wall / Voltage wall. Now It Run's @ 4.0 Ghz no trouble And if it was under water it would def be 4.2 Ghz stable also but to much heat on a hyper 212 past 4 Ghz.
Other units i ran into a very similar wall @ 4.2 & 3.8 The big thing is Most will run different voltages and QPI settings as-well, which is why i'm sure its board dependent.
You have to work up your OC's from scratch basically every time, Their are guides out there but thats all they should be used for imho "Guides" if you try to just plug their numbers into your mobo you will have poor/varying results.
I've seen some boards that can run most settings at just Auto & some that need every single thing changed manually.
That said their are Definitely RULES you need to follow while ocing 1366 you will find those certain rules in the guides.
GL with OC.
1366 / 1156 Guides
