- Jul 18, 2011
- New Brunswick, Canada
I'm currently running the following:
Intel Core i7-930 Bloomfield at stock clocks and voltages (2.8GHz, 1.28V)
EVGA E758-A1 3-Way SLI LGA 1366 mobo
Cooler Master V8 with AS5 thermal grease
All installed in an Antec 1200 with good cable management and great airflow. Ambient temp of the case is roughly 20C.
The bios temp monitor tells me my system is running at 21C and the CPU is at 29C.
However, third-party programs such as realtemp, coretemp, and speedfan, all tell me the cores are idling at 40-44C, and reaching 74C at full load using Prime95.
I don't understand how the cores can be so hot at stock clocks and voltages. I have tried cleaning all of the fans and fins to ensure maximum cooling capability. I have also tried re-seating the heatsink.
What's interesting is that the onboard LCD displays 32C idle, and 58C at full load. These temps sound much more accurate for my situation, yet all third-party temperature monitoring programs are giving me extremely high temperatures.
If interested, I currently have three 120mm fans pulling air in the front of the case, and a 120mm side fan pulling air into the case. There are two 120mm exhaust fans pushing hot air out, and a top 200mm fan pushing out. The heatsink's 120mm fan is blowing hot air towards the exhaust fans. Every fan in the case is currently running at 100%.
Both of my GPUs are idling at 28-30C, so the overall cooling of the case is wonderful.
What could be the problem with these abnormally high CPU core temps? I was hoping to overclock this chip over 4GHz, but I'm pretty shocked at the moment.
