brian2one0
- Aug 15, 2016
Recently just overclocked my i7 980x to 3.8ghz. Didn't want to go too high because it's an old card. It's my first overclock so I followed all the guides and read up a bunch on what all the settings do but could still use some feedback. I've ran a Prime95 test with these settings and didn't bluescreen. Highest temp was 68c.
Processor: i7 980x
Motherboard: Rampage iii Extreme
RAM: Patriot Viper II Sector 7 Edition 24GB
GFX Card: GTX 780
I have an aftermarket heatsink. No water cooling.
CPU-Z:
CPU Ratio: 29
BCLK Frequency: 133 (I read for 980x you can leave this at default and just up the CPU Ratio. I have no idea if this is true or not so help with this would be great)
PCIE Frequency: 100
DRAM Frequency: DDR35-1600MHz
UCLK Freq: 2400MHz
QPI Link Data Rate: Auto
Load Line Calibration: 50%
CPU Voltage: 1.22500 (blue screened prime95 with 1.21875 with these exact settings)
CPU PLL Voltage: Auto (this is one of the settings I literally have no idea what to put it on. It's on Auto which means it's at 1.812v and that seems really high for what i'm doing. If anything any help with the PLL would be great honestly.)
QPI/DRAM Voltage: 1.21250
DRAM Bus Voltage: 1.64300
IOH Voltage: 1.11300 (I read the guide here for i7 overclocks and it says that if you are using 1 gfx card you should always set this to 1.1v. Is that true? or is that outdated information.)
IOH PCIE Voltage: Auto (it's at 1.508v on auto. It's another that I have no idea what it does and can't really find info on what to set it to so any help on this one would help a lot too.)
ICH Voltage: Auto (Auto is 1.11 again not sure about this one)
ICH PCIE Voltage: Auto (No idea what this is, With it set to Auto it shows that there is no voltage)
Like I said this is my first overclock so I feel like I messed something up. Any help would be great, thanks!
Processor: i7 980x
GFX Card: GTX 780
CPU-Z:
CPU Ratio: 29
PCIE Frequency: 100
UCLK Freq: 2400MHz
