- Nov 25, 2008
At that resolution, I don't think you would see much of a difference between a 9800 and a GTX280, and even less between multiple cards.
If your seriously not planning on using resolutions over 1280x1024, then I would spend a LOT less on the graphics card. (I wouldn't go over a 4870 or a GTX260, you might be able to get by with a 4850/30 even)
Instead, I would spend more on the CPU. If you go for LGA775, your much better off with a P45/35 instead of a nvidia chipset, you'll be able to get much high clock speeds. A i7 would also be a good choice, if you can afford it.
EDIT: I like how long it takes me to reply.
If your planning on SLI, you should probably be at about 1920x1080. If your planning on buying something like 2x 280GTXs then you should probably be even higher.
1650x1050 seems to be the average nowdays. If your willing to turn the setting down just a tad, you can get by with a pretty cheap (9600gt) graphics card as well.
