- Jun 15, 2003
- Cedar Rapids, Iowa
Let's just go over some basics here...
You've got a rotary compressor so that's not your problem. I'm assuming you're using your A/C's condenser so that's more than enough (size wise). You've got about 10' .031 cap tube. Cap in cap evaporator (maybe describe how you built it? How many caps/how big of holes drilled/etc.). Propane for refrigerant right? If you apply more load (higher vcore) temps skyrocket.
How long do you let it run for it to cool off? One of my builds took like 5-10 minutes to get down to the lowest temp, maybe you should let it run a bit longer?
Don't worry about what others' systems do. What you'll want to do for tuning without worrying about superheat and the such is get your processor running at it's highest load and highest vcore you feel comfortable with (basically make the processor as hot as it'll ever get), then add propane as the processor is loaded.
Get enough gas in there so that temps don't skyrocket when you add more vcore, load up prime95 (or orthos if you're running dual core). Watch temps via whatever program you have and add like 1-2 second bursts of propane to the low side and wait like 3-4 minutes between adding more to watch the temps. Temps will lower until they stop lowering where you'll want to give it one more 1 second burst of propane for good measure which will slightly raise temps but you shouldn't have to worry about overheating the compressor as much.
If this way of tuning still doesn't work for you then you might want to cut a foot of the cap tube and see what that does for you. If that doesn't work then the DIY evaporator is at fault... Just some speculation, but it might be filling with oil and the excess refrigerant is needed to flush it out.
