trendx said:Before we get started dont forget that I am bringing over my 7800GTX, OCZ Powerstream 520Watt PSU, 74gb Raptor, DVD/rw drive.. Any comments accepted. Thanks again.
Asus P5W DH Deluxe
http://www.newegg.com/product/product.asp?item=N82E16813131025
Intel C2D E6600
http://www.newegg.com/product/product.asp?item=N82E16819115003
Crucial 2 x 1GB DDR2 667
http://www.newegg.com/product/product.asp?item=N82E16820148017
Artic Silver 5
http://www.newegg.com/product/product.asp?item=N82E16835100007
Thermalright SI-128
http://www.frozencpu.com/products/4...8_-_Athlon_64_and_Pentium_4_S775.html#options
Black PWM Fan Controller
http://www.frozencpu.com/products/9..._6x_Fan_Controller_525_Bay.html?tl=g34c17s286
IYIENACE said:lol and 2GB of mem only this is the set I picked http://www.newegg.com/Product/Product.asp?Item=N82E16820220095.
I also ordered my MP-1 & MP-05 blocks yesterday. Looks like we will both be .
trendx said:Also I would wait on your nb and cooler, see once u get your system up if your case has good airflow it shouldnt be a problem. I also went with the ultra 120 instead of that si 128 just because i decided to be pimp status. your motherboard airflow isnt something you should worry about so much if you have some nice case fans or even use the optional asus fan for the sink on the mobo. For the videocard, thats all about preference? Do you play many games? I wouldnt try to go top of the line right now since the next generation is right around the corner, try the cyberdeals section to see if you can pick up a sweet card for cheap.
enz660 said:oohhh yeah, I got that same ram from the egg for $179 JUST before the price went through the roof
you will be happy with that ram.
IYIENACE said:Are you maxed at 3.4ghz? What would you say this ram will do? I actually bought it w/o really doing any research but the reviews there looked decent. Have to take most of what you read there (Egg) with a grain of salt these days.... Any advice to get me off and running with timing etc?
