*** thanks otter and everyone else for your help and comments, i'm getting closer and closer to my first fully custom watercooled pc ***
guys, just an update, i was able to use this adapter 120vac > 13vac -
http://www.radioshack.com/product/index.jsp?productId=2049687&cp
to power the koolance pc2 pump. i've into the 4th hours of testing my loop, my first EVER custom loop
i'm hoping this setup gives me better performance that the regular koolance pc2 because instead of 3 x 80mm fans, i'm using 2 x 120mm fans.
in the pc2 theres a plastic flap on the underside of the rad that stops the air to pass through from the 3 x 80mm fans. the flap is there to direct air on the controller board which gets very hot.
since i'm not using the controller board(controlls pump and fans) i don't need this flap, it literally blocks air from passing through the rad for more effective heat dissapation.
i'm going test the loop for 24 hours +. i'll update later and report temps. i'm hoping to run the following voltages.
vcore 2.15
vdd 2.1
vdimm around 3.4-3.6, i'm modding my case for some fan to blow over the dimm slots.
vagp will stay at 1.6.
my goal is to get 2.6ghz, 2-2-2-x, 1t with 2x512mb of ram(actually dimm1 - 256mb, dimm2 - 256mb and dimm3 - 512mb in dual channel).
wish me good fortune
