- Mar 30, 2013
- Maryland
Is there some kind of adhesive and foam I can buy to glue to the inside of my case or what? help me out guys
http://www.amazon.com/Cooler-Master...d=1366513718&sr=8-2&keywords=coolermaster+fan
It has good reviews and it would be quieter in case your current fans are loud for the airflow.
I, being a cheapo, went with Scythe S-Flex, but I agree that Noctua's are great (if you can afford 8 of them at once ).
Tru dat.
But worth it the first time you press the power button and think, "Maybe I didn't press the power button hard enou...oh ****! It IS on! FD$%K that's quiet!"
That happened when I replaced my older Hitachi 300GB in my HTPC with a 60GB SSD. I turned it on and said wtf? But yeah I didn't realize how loud those older hard drives are.
I run 4 of those 120mm orange Xigma fans on a fan controller. I normally keep them around 1000rpm, but I have set them down to ~700RPM in the past and they are quiet.
All are using the Low Noise Adapters that Noctua supplies. They may look like ***, but they're like silent little cooling ninjas in my case.
