Config info:
Xigmatek Midgard Tower (2x 120 installed, could add 5x 140 fans)
AMD Phenom x4 945
2x2 GB DDR2
ATi 5750
One SSD and one HDD.
I used the fans I got with the hardware for now, but they seem quite loud, even when they're not under load. I looked for other fans, and while they are more quiet, that doesn't solve the issue of dust for me.
So, I think that left me with two options, but as I don't have much knowledge about this kind of stuff, I don't know if they are realistic / feasible with my case.
- I can get new fans for my CPU and GPU, which should be a little more quiet, and install dust filters in the air intakes. I'm not sure how I should install those, but I assume there will be space in my case for this option. It's the cheaper option, but I'm not sure about how quiet I can get with such a setup.
- I can also use watercooling, my case having space for a 120.2 radiador, plus holes for the cables. I don't think the pump + T-cable should take that much space. In this case I'd lower the noise a bit, but what 120-140 are the most quiet, while having decent flow.
What is typically the difference in price, difference in OC potential, and difference silence-wise, if any?
AMD Phenom x4 945
2x2 GB DDR2
ATi 5750
