- Jul 15, 2008
- Suffield, Connecticut
Recently I've been experiencing a few issues with my new build. Every time I shut down my PC and leave for work, it refuses to boot when I come back. It'll turn on for about a second, at which point fans spin up, LEDs blink, and then everything shuts off, and the cycle repeats indefinitely until I switch off the PSU. The PC will not boot successfully until I pull the power cable, open my case, and reset the BIOS battery. After that happens, the system will boot. I can also successfully restart from Windows 8 without a hiccup, or shut down momentarily and the boot up again. But as soon as I walk away for a few hours, nothing works when I come back.
I'm not sure if it makes a difference, but when I wired the system initially, the 8pin CPU connector was not compatible with the 8pin port on the motherboard. Only 4 of the 8 pins would fit. I've heard this is due to an incompatibility in ATX12V and EPS12V, but I'm confused because Corsair published that my PSU (TX750 V2) was going to be Haswell compatible.
I appreciate any help that anyone can offer. Full system specs are in my signature. I'm curious as to which component I should replace; the PSU or the Motherboard...or maybe something else entirely.
EDIT: I've also updated from BIOS F1 to F3 and the issue has persisted.
