I take out any drivers where possible, but if the change isnt a big one....intel to Intel for example, I usually just let windows fix itself on first boot. If it is Intel to amd, while I've done that before, I typically reinstall from scratch.
You should partition your drive and separate windows so you can easily wipe it out and put it back on.
You will need to reactivate Windows 10 since changing the motherboard will invalidate the original activation. I would use a free ap called Produ key to extract the current activation key if you don't have access to the original install media and original product key. After you extract the key, write it down. You can then use it to reactivate Windows but you might have to use the Microsoft automated robo phone activation tool.
The only thing which is causing issues for me while switching platforms is a storage driver. If the driver is in the OS then all will work, but Windows will search for the right driver some longer. I had no issues moving OS between new AMD and Intel chipsets. On new chipsets and Win10 it's much easier as Win10 has almost everything built-in. The only exception can be RAID drivers but even then it sometimes works.
