- May 12, 2004
I have recently decided to build a new gaming rig, and i was in a debate over the Pentium D Dual core, or the AMD Athlon 64, i have heard good things about both. Some tell me that Pentium D is meant for servers, others say it's a great choice for gamers. The same goes for the AMD 64; some say that it is an amazing cpu, and others say, that becuase most programs are not built to run on 64bit, it is a waste to buy one, because it is only truly running on 32bit, and there would be no noticable performance increase. as of now, my comp is as follows: amd 2200+, powercolor radeon 9600SE, 768MB ram, 2hdds (20+80), so as you can see, almost anything would be an improvement over that. I just want some help deciding what processor is the best choice for gaming.
thanx
hook
PS, i wanna spend under 750 on the mobo, cpu and video card
thanx
hook
