- Feb 18, 2002
Wireless Logitech G700.
Confirmed this was a hardware issue by simultaneously plugging a wired mouse which made no noise when it was used, while at the same time not-so-loud high pitch was noticeable when using the wireless mouse. It appears some kind of interference is the culprit.
Was not successful in finding out where the pitch is coming from. It doesn't appear to be speakers. The sound is not constant. When it happens, it only happens when moving cursor across screen.
_____________________
Intel i7 950 [206] BCLK x 20 = 4.12 GHz @ [1.4000] CPU Voltage & [1.35000] QPI/DRAM Uncore Voltage, Batch 3029A40
2 x 4GB Kingston HyperX T1 DDR3 1600 (PC3 12800) [DDR3-1651MHz] 9-9-9-27 @ 1.66 DRAM Bus Voltage
ASUS P6T Deluxe v.1 [LGA 1366 Intel X58] BIOS 2209
Thermalright Ultra-120 eXtreme 1366 RT with 120mm Scythe S-Flex F fan
ATi Radeon HD 7870 XFX Black 2GB HDMI 2XDVI GDDR5 1050MHz Core Clock
OCZ Agility 3 180GB SSD
Asus Xonar DX sound card
Antec nine hundred case, two front 120mm fans, one back 120mm Fan, one top 200mm fan
Corsair CMPSU-750TX 750W
