- Feb 14, 2003
- USA
Asus A7M266-D rev 1.04 BIOS rev 1011.003 (board does have USB ports and headers)
2x 1700+ DUT3C JIUHB @ 2128
*Edit: this is set up like the board, AGP down the PCI/66 to PCI/33 slots
GeCube Radeon 7000 64MB AGP4x
Intel 1000MT Pro Desktop (66MHz?)
Promise TX2plus w/74GB Raptor (trying to make it bootable) (66MHz?)
Was an Audigy Platinum eX
The eX expansion/connection to external breakout box
ATI TV Wonder Pro (no remote since one will be coming with my 9600XT and I have a Windows MCE one also)
I've had Windows 2003 running fine on this lovely girl for a week or so. I've been tweaking with it to find the highest speed I can get and still stay within the range of my nice'n'quiet Silent Boosts. So far 16x133 (I'm trying to keep the PCI bus within spec.) seems to be a pretty good bet, the only issue being that my idle is 43-45C in Windows according to MBM and if I start priming I'm betting it will go past 50C which is my comfortable maximum. But since this is going to be an encoding machine and also store my movies (DVD backups and such) I wanted to put a TV Tuner card in here along with a decent sound card so that it can become an HTPC (among other things). The first issue I noticed was when I thought about putting MCE on here. (I have an evaluation version that a friend who is a computer reseller picked up for me, since MCE2005 has been talked about as being white-box friendly.) The remote is IR wireless and the connection is through USB, but all my PCI slots are full (well the one is covered by the eX drive expansion card) so I tried enabling the onboard USB ports. It seemed to work fine, but then partway through the install of MCE, just as I was putting in the size I wanted for the partitions on the Raptor, I get one of two outcomes: 1. the computer will BSOD with an IRQ_LESS_THAN_OR_EQUAL error or 2. the computer will just reboot itself. The funny thing is that it only happens when I hit any key on the keyboard after hitting C to set up a custom partition, I'm going to try just using the default of the whole drive. At first I thought it was the keyboard doing it because I would hit Num Lock to use the number pad and it would BSOD or reboot. Using the whole drive seems to be working, but I wonder if Partition Magic will be able to resize the OS partition without making things mad. On a side note, with this controller it seems to be taking quite a while to format the partition, I've had larger Western Digital SATA drives go much faster (on the Asus A7N8X Deluxe onboard SATA controller), is it the fact that XP is having to use the PCI 66MHz bus? Or maybe its not actually running the bus at 66MHz?
Does anybody have any ideas on a way to fix this? I'm still pulling out cards, the sound card is out and I'm going to pull the TV card next, but I'd like to be able to have all my cards in and useable, and I'm thinking of experimenting with the USB onboard again since without it my MCE will really only be XP with TV, minus the remote which makes it worse than XP for TV purposes. Any help would be appreciated greatly, as this is gong to be running one of the 120GB WD SATAs that I used on the old box as a primary OS drive rather than the Raptor, I'm just testing it with the controller since I thought I read somewhere that the TX2 supports TCQ which is something the Raptor can use.
