- Jun 7, 2011
I dont know, how important is it to restart system after LAN driver install?
I forgot to restart because i had to install countless stuff. Every single program demands a restart which is just painful. Including updates took me hours to make all the stuff finish and ready.
Could i possible get corrupted update data when LAN driver hasnt been restarted? I made restart after OS update.
The LAN driver basically works as soon as installed, and Windows is trying to make a home network and is connecting to the Net in a instant. But its still asking me for a restart after driver install. I just wanted to install all the other drivers first (instead of restarting for every single driver) and then forgot to restart.
The only issue is that the OS was updating (without restart between)... and there is no way to check file integrity in term of a malperfoming driver. I have no access to the detailed file values. I hope the OS is checking the integrity but im not so sure about because its Microsoft... not the wisest of all geeks.
Another issue is that there seems to be no AHCI enabled but why? In the MB AHCI was enabled from the beginning. The other issues such as that the OS is unable to install to a drive when any of the other drives are attached, is another headache but just how it is. It says it doesnt support MBR on UEFI boards for install or other messy things but i got no clue what it actually means, because it wanted to install itself inside a GPT HDD with 4 TB size but cant handle a 120 GB MBR drive... its just headache. Ok, if it cant handle a MBR why not to accept a reformat? It was even accepting a reformat but didnt want to install, prehaps a reformated disc is still MBR, but the OS did so, its hilarious.
