- Jul 15, 2013
hello i have an HP computer with a 240 watt proprietary psu. is it possible for me to take a standard 24 pin ATX psu and repin it so the wires in the ATX psu motherboard conector conector match thoes in my proprietary psu.i tried plugging my ATX psu into my mobo and the pc started beening telling me it wasnt getting the recomended amount of power heres my psu specs
power supply:240-watt 85% efficient* BTX power supply – Active PFC
operating voltage range:90 to 264VAC
rated voltage range:100 to 240VAC
rated line frequency:50/60 Hz
operating line frequency range:47–63 Hz
rated input current:3.5A/1.75
heat dissipation:Typical 270 btu/hr
(68 kg-cal/hr)
Maximum 1025 btu/hr
(258 kg-cal/hr)
power supply fan:varriable speed fan
(68 kg-cal/hr)
Maximum 1025 btu/hr
(258 kg-cal/hr)
