- Nov 16, 2001
I have been trying to achieve the magical 4 ghz with a 3.2 Prescott for some time now, first with an AI7 and then a Max3, which was at the time supposed to be the BEST Precott board. Now I find that it TOO has a vcore droop problem. I saw just how much last night. I set the bios to 1.525 and that allowed Abit EQ to read 1.5 at idle. But when running PCMark2004 the vcore dropped all the way to 1.42. I do not trust my skills to do the Stickied Droopmod and besides with having to buy a digital MM it is probably just as cheap to buy another m/b. I'd probably screw it up and have to anyway. But I am fond of the Max3 and I have grown accustomed to having at least 3 ide ports along with the SATA Raid and another SATA drive. Not to mention having already cut up an Antec P160 to duct intake air to the cpu at the position it is on the Max3. What I really need to do is the mod but I just don't trust myself doing it. So is there another board that would have the same amount of SATA and IDE ports plus the same cpu location BUT NOT HAVE a voltage problem? I even looked at getting a Fatality but not enough IDE's and I am sure it has it's problems, too. Or maybe should I just give up and go A64? Or maybe I should just be satisfied with 3640ghz. I have thought about another cpu besides the 3.2 C0 but I now figure a new one would still have the voltage problem.
And to top it all off, I did not get this typed in time to post in the 10 minute window the local Network Nazi's allow for AM break. It will now have to wait until lunch to punch submit
