- Apr 14, 2011
Asus M5A99FX R2.0
G.Skill 1866mhz 16gb
MSI gaming Geforce 1070 (also tried testing with r9 280x)
HX750 PSU (also tried CS500x PSU)
Corsair H100i cooler
This motherboards CPU_LED light stays stuck on.
i have re-seated the CPU and memory
I have removed the CPU and memory and turned the board on. CPU_LED still stays on red.
i have checked the pins on the CPU. nothing bad there.
i have attempted to use bios flash back but based on w hat i am seeing, i am already using the latest.
I have removed the battery and did the jumper at the same time for a good minute.
i have replaced the power supply.
Now something tells me that if removing the CPU and then turning the board on still shows the cpu_led staying stuck on red, i should buy another CPU and hope it works...yeh?
