- Jan 3, 2004
- Oregon
I didn't think I'd have to ask a question like this, but I now have myself wondering a few things.
Okay, Here is the deal. I've done some work on my computer and I was wondering if any of it did any good. I know it works, because I'm on it now. Nothing has fried and it doesn't freeze. Here is the thing..I think it's hotter than it should be. What do you guys think? Here is what I'm currently using:
SLK-900a lapped with 2000 grit wet/dry paper
2500+ stepping AQZEA running at 200x11 (with a MBM recorded vcore of 1.72)
92mm Delta fan (the one big one from sidewinder computers)
Arctic Silver 5 that has been set for weeks
Asus A7N8X Rev.2
Now that I've listed the important comporents, here are teh temperatures I'm recieving. All of them are as reported by MBM since I do not have a good thermal probe. The only one that is calibrated is my room temperature. I use a Radio Shack digital thermometer for that. All temperatures are celsius and idle.
31c Motherboard
41c CPU
48c CPU Diode
29c Room Temperature
My airflow in the case is plently good and my wires are properly managed. I'm thinking my main problem is that my voltage is set rather high. In the bios settings, it is set to 1.65 (which used to run at 1.63 untill a day or so after installing my new motherboard [had A7V8X-X before...if that's important. Both read 1.63 for a while]). What do you guys think?
Asus A7N8X Rev.2
31c Motherboard
41c CPU
48c CPU Diode
