- May 16, 2013
- East Coast
Hello everyone!
I am not sure whether this is the proper place, but you helped me a lot when I built my current PC nearly 5 years ago, so I thought about asking. My current build (see signature) has worked flawlessly for all these years, till last weekend.
I turned off the PC on Friday. When I tried to turn it on the next day, it did not show any sign of life. Not even a single bip or light. The only "different" thing I did on Friday, was to turn off also my UPC. Have done this many times in the past years, though.
I tried to change socket and cable, to no avail. I have tested the PSU with one of those 24-pins jumpers/switches and the fans/pump appear to work perfectly. I have tried to disconnect different stuff (GPU, RAM, etc...) from the motherboard or start the PC from the motherboard, but still nothing.
The only time I notice some sign of life from the motherboard is for a brief moment after starting the PSU with the jumper. As I plug the cable back into the motherboard, the audio card lights up for a brief moment. That is the most I managed to achieve.
Should I test the PSU with something more fancy to verify whether it can start the fans, but not the whole system? Or should I declare the PC dead?
Thanks!
Thanks!
