Is there any hope, or "a p.c.'s series of unfortunate events"
Hi guys,
In a nutshell, do I have any hope of repairing my 300 gb hard drive by installing a new PCB onto the drive?
Me and my computer have been through the ringer lately. I recently bought a PATA Seagate 300 GB monster drive to try to reconstruct a damaged raid array. I used RaidReconstructor and GetYourDataBack for NTFS. It worked to degree, though some of the files were still corrupted--but I did get most of my files back.
But then the drive became corrupted. It appeared to be an ongoing problem with the MSI K8Neo4 Ultra motherboard, which I have had to replace since then. I thought at first that it was just a dead raid drive, but I was wrong.
Anyway, in the course of trouble shooting this problem, I had the 300 GB drive hooked up to a legacy Athlon XP Windows 98 system.
Because the drive was NTFS, I installed Windows XP on another spare WD 30gb drive, I had lying around. I got sloppy, though. Rather than mounting the WD and Seagate in the case, I simply hooked up both and placed them on the floor on the outside of the case.
Then disaster. I moved my wheeled chair into my desk, and one of the wheels hit the two drives on the floor.
The legacy system seemed to suffer some kind of short circuit and shut down.
However, the primary WD drive was fine. The 300 GB drive was still unreadable, though.
At this point, I decided better safe, than sorry, and I unplugged both drives and put them back on the shelf.
When I replaced the motherboard, I tried installing the 300 gb drive in the new system to see if there was any way to recover any data from it now.
So I installed the drive into the drive bay under the floppy drive. I plugged everything in, and powered up the machine.
And then I let the smoke out--lots and lots of smoke. It kind of reminded me of a spinning firework on the 4th of July. .
I couldn't tell if it was the floppy drive or the new hard drive that was smoking, but both were toast.
There were scorch marks on the floppy drive's case. One of the chips on the PC Board of the hard drive looked as though it had melted or had been partially burned off.
Which leads me back to my question: is there any hope of salvaging the drive with a new PCB? Or would I merely be risking further damage to the other components attached to my system?
Hi guys,
