- May 29, 2012
- Perth, WA-Australia
Hello All.
This is my first post on OverClockers and i have some questions about my new fan setup. I recently built my first rig in a CM 690 ii Advanced case and put some fans in that my friend gave me.
There is a fan controller that controls the cpu fan ,blue top exhaust and the 2 140mm intake fans.
The other fans are controlled by the mobo
All the fans are shown in the pictures except a 80x80x20 exhaust fan on mounted behind the cpu.
My Rig
Exhaust
Intake
Edit
The idle temps of my graphics card is around 35C and the cpu is around 30C
Load temps for gpu is 72C While overclocked and cpu gets to around 60C.
With all fans at max speed there is a negative pressure(mainly from high cfm blue exhaust fan). I can tell this by putting a tissue on the side vents(I put 2 layers of flywire for filtering) because it sticks to the side. I did also have a side filtered intake fan but all it seemed to do was blow dust into my graphics card so I removed it.
My questions:
Is this a good setup?
Is the negative pressure ok?
are these temperatures ok?
Also is it better to have the psu how i have it or the other way around so that it sucks air from inside the case rather than the outside air?
This was my first attemt at making my own computer and im only 16 so please no harsh comments.
Thanks in advance.
My Rig
Exhaust
Intake
Edit
My questions:
Thanks in advance.
