It should work without issues. At least I can't see there any traces. You won't know for sure till you test it.
I had something like that on new ASRock board and it was working fine.
My main concern is do these motherboards have multiple layers? Using the image of the back of the motherboard, if its just that one trace AND its broken, I could fix that myself... but if there are layers in between layers, then that's an issue.
