- Jun 28, 2012
Tell me why I shouldn't go with Intel?
You should, get Skylake.
I'm just not into this integrated GPU nonsense. Use that space on the die for more cores or fewer, more powerful cores. I'll supply the GPU. But then, I've been at this for too long and am set in my ways and cranky...
^^^This^^^If you don't like the iGPU, just don't use it.
I'll say this though, if you ever have a GPU die on you that iGPU is suddenly your best friend.
I understand that, but my point is what are we missing by having a GPU on the CPU die? How much more powerful of a CPU could it have been? How many more cores could have been added? If I was building a console gaming system, it would make sense. It is just wasted silicon to me. Anyway, beyond the point of this discussion.
You miss the point. If the GPU wasn't there, the silicone could be used for something crazy, like more CPU or something. To me, the combination is bizarre and unnecessary. What are they trying to accomplish?Nothing. Because if you want more cores you go buy into the -E lineup.
I am not saying that the integrated GPU is bad or of poor quality, but that it is superfluous.and if you just surf the interwebs, watch tv and other mundane things an igpu is plenty good and adds no heat to the case and with that comes less fan noise.
Let's get to the "meat" of the story. The Quote that you posted from a "Newegg" Review doesn't mention what board ASRock is refering to. To my knowledge only the 990FX Extreme9 supports the 220W CPU's so let's safely assume that's the board we're refering to.
A stock 125W CPU will NOT require a spot fan on the VRM's to keep them cool. Adequate case ventilation along with the stock VRM heatsink will do just fine. However, spot fans will HELP keep this area cool and I would always recommend them on any board running AMD FX line. They ALL get warm.
A stock 220W CPU, we all know we are referring to the FX9xxx series here. Well, The FX9xxx is just a factory overclocked FX8xxx. Yes they have higher P-States but it is essentially just an overclocked FX8. Will it require a spot fan on the VRM? Maybe not, but in my opinion it absolutely should have one. Will it overheat without one. Probably not under normal load conditions but with CnQ and all the other power savers turned off and putting under extreme loads like benching or stability testing then it very likely could. I've read several posts from some very trusted members that will tell you that even at stock the FX9 will throttle its self under heavy load, at stock mind you.
Now, if you've read through all that and are still with me I'd like to say I do agree in part with you. I believe the board should come with a factory fan pre-installed on the VRM's so you don't have to add you're own. I've seen other much older boards with this. The issue with those were that they were loud and annoying and most people just pulled them off anyhow.
The fact is we're talking about the largest heater this industry has seen (to my knowledge). The best option of course is to water cool it. Now that's even more money and will drive the price out of most peoples price range.
I'll go out on a limb, and say that probably even a Crosshair V would need active cooling on the VRMs for that chip.
