- Jan 30, 2013
- Saint Cloud, FL
Recently built a new desktop on 1/1/2013. Got an i5-3570k. I have overclocked in the past, both with Core 2 Duo's, one in my old desktop a few years ago and more recently my P7350 in my G51VX.
I have an Asus P87ZZ-V LX mobo with the latest bios. I have been able to successfully, after much trial and error, push this baby to a stable 4.5 Ghz. -- BUT, my core voltage needs to be INSANELY high to due so. I am currently at 1.408 volts...
I have great cooling, at stock 3.8 ghz with turbo mode and 12 hours of prime my max temp was 62c. At my current voltage, idle temps vary from 36-38c on all cores, and after 12 hours of prime, my temps hit 81c. I have a Cooler Master N 520 heatsink with the two stock fans in Push-pull. Also used AS5 as my TIM.
I really don't think these voltages will necessarily hurt long term as my temps are not the bad during daily use, an hour of ArmA 3 Alpha and my hottest core temp was 66c. But perhaps I am overlooking something in the BIOS?
I have multiplier at 45, LLC to 75% (Very High in asus bios i believe), cpu power to 120%, Phase mode to extreme, and PLL overvoltage turned on. I have left all C states on as those effect stability, and turning them off I was not able to drop my voltage any further. Note i have voltage set to 1.4 exactly in the bios.
Here is my CPU-Z validation, in case anyone wants to see it for reference.
http://valid.canardpc.com/show_oc.php?id=2742685
This is my first hardcore overclock, but I did have my 2.0Ghz core 2 duo in my lappy oc'ed to 2.5 (25% oc) after modding it. I ran 2 plus years without having to increase or decrease the voltages on it.
If anyone can point me in the right direction, please do. Either I got a really bad chip (mine is a costa rican one), or I am messing something up big time in my bios settings.
