Ok, first off.......I've found that this setup is almost the perfect combination of parts(I tried many), because it allows the full range of fan speed to the full range of the pot.
parts:
10k linear pot(radioshack # 271-1715)
NPN transistor(TIP3055) (radioshack # 276-2020)
heatsink(radioshack # 276-1368)
heatsink grease (radioshack # 276-1372)
wire/perf board
The nice thing about this transistor is that it can handle 10 amps at the collector, which is plenty for even the most 'power hungry' collection of fans, if cooled properly that is. I've tested it out on 2 120mm high velocity fans each pulling 1.2 amps. The heatsink was hot to the touch, but being that the maximum operating temp of the transistor is 150C, it could still handle more. Also, this setup only sees a voltage drop of .3v.
When I turned the pot all the way to max resistance, the fans slowed to the point of absolute silence. If the fans are turned on while the pot is at full resistance, the fans will not turn unless a little more voltage is given to get them going. This is how you can tell this is the best pot for this setup.
On too construction......On a transistor, there are 3 pins, the collector(pin2), the base(pin1), and the emitter(pin3). Solder one end of the pot to the collector(2), and the middle of the pot to the base(3). Solder a lead(red wire) to to the collector(2). Finally, solder a lead(black wire) to the emitter(3).
Now just apply some HS grease and bolt on the heatsink, thats it.
And yes, you need the heatsink for heavy(as in above 1a) amperage loads.
Enjoy all......
oh, and one more thing, I have no idea how efficient this is. Anyone good at calculating efficiency percentages, please post it......
parts:
wire/perf board
Enjoy all......
