link to album with the build progress Air / Cpu loop/ Cpu+Gpu loop
Temps are great on both Cpu and GFX with a decent overclock
Fans are nearly silent
ryzen 1600x @4.0ghz - 52.5c Max Load
Gtx 1080 Gigabyte Xtreme WB - 2177mhZ / 5178Mhz - 48c Max Load
Not as clean as i would of liked in the end i think with some more 45/90 degree fittings better can be achieved
3/4 tubing is pretty big in this case and probably would go with 5/8 if i did it again.
Reservoir mounting was a pain i had to drill holes into the cable management bar to mount it sideways, originally i wanted to mount it between the GFX and Rad vertically but couldnt fit it with D5 pump base
Would of like the res mounted closer to the glass but cant make it with current fittings
Will do for now might tidy it up and re route some things in 6months when i drain it
