My system:
i7 930
ASUS P6T SE
Corsair H50 with 2x GT AP-15 for push/pull
Antec 900 (semi-modded)
G.SKILL 2x3GB (6GB) RAM (rated at 1.5V DDR3-1600)
Hey guys, I just finished setting up my first aftermarket cooler system: H50 with it's 2x AP-15 push/pull fans. I need some help on how to OC my i7 930 since I haven't truly OC'ed in a proper way, ever.
Anyhow, I ran Prime95 (Large FFT test) and tested for 20 minutes on my i7 930 running at stock 2.8 GHz. Everything passed. Using CPU-Z, at 100% load my CPU read 1.240V. My 6GB RAM was also running at its non-OC'ed DDR3-1066. My temperature readings using Core Temp after 15 minutes of 100% load were: 57, 54, 57, 53 for each of the cores.
All settings in BIOS are currently at default in terms of clocks/timing/etc.
I am trying to reach a 3.6 GHz (maybe 3.8 GHz later) overclock as well as OC my RAM to its rated DDR3-1600 speed. My questions are as follows:
1) How should I approach this? What settings would I need to change/mess around with to get a 3.6 GHz O/C (is there an easy way or some basic settings I should try)? Do you think with my current temps, this is doable?
2) How do I go about finding the right voltage? I think mine is auto right now at stock... Any settings you guys can list for me to try right now? I have read some guides, but I was hoping for something to try real quick, and then work my way from there.
3) Am I still able to have HT or the SpeedStep enabled? I like my system right now where if I am idling...the clocks will slow down to a slower speed. Slower speed = low idle temperatures (although idle means nothing). But I also would like it to be able to get up to 3.6-3.8GHz when I am pushing it/playing games/when it needs to be. Is this still possible with an OC? Not sure if an overclock would turn these things off and force my CPU to run at its max speed all the time.
4) Browsing over the G.SKILL forums, if I wanted to OC my RAM to its rated DDR3-1600 @ 1.5V, all I would have to do is set it to the "XMP-1600" profile in its BIOS. Or I could manually set as well. Is this the best option as well? Does OC'ing my processor automatically OC the RAM too? Or would I have to set it to that XMP profile?
Thank you!
i7 930
ASUS P6T SE
Thank you!
