- Mar 14, 2004
- Massachusetts
I just finished installing my new Swiftech mcx 478-v. it was pretty easy to install. had to do some modifications to get the 120mm delta fan to fit. the bracket i got was the clear acrylic 120 to 92 mm fan adapter. withe some use of my leatherman and my drill i made some bigger holes to fit a screw driver through and all was well.
after about 15 mins of it running my idle temps are at 42c - 44c which i believe is a little high for this new hsf. i used some as3 i had laying around. im hoping that its just because the as3 hasnt settled yet but still any extra thoughts might help thanks
